Will these fit into this Q-Form Kick Panel?
warsoul
Post by warsoul »
Hi All,
I Have a 1997 Mitsubishi Eclipse GS with Infinity System. I'm looking into getting these Q-Form Kick Panels for the car:
http://www.crutchfield.com/S-98WlRpPP51 ... 300494#Tab
I'm a little confused as to what will fit besides 5.25.
It says:
"Giving exact mounting depths is not possible, since it will depend to some extent on the space available behind the factory kick panel; however, the minimum flush mount depth for the tweeter is .75" and 2.5" for the woofer/mid bass component. Per Ai Research, the maximum allowable speaker depth is 4".
This unit allows you to mount a tweeter with a maximum diameter of 2.34" and a 3 1/2" to 5 1/4" midrange/midbass unit. The maximum frame width/diameter allowable for the midrange/bass unit is 6.3", so a few 6.5" units may fit. Make sure to check the specs/features for frame width and mounting depth of any components you sell."
I was wondering if someone could tell me if these would fit
http://www.crutchfield.com/S-98WlRpPP51 ... 8607CS#Tab
This may be a better picture to give you an overall idea of much space they take up:
http://www.sonicelectronix.com/images/big/big607cs.jpg
I looked up the owners manual on the infinity website and found this:
60.7cs
Type: 6-1⁄2" 2-Way Component
Crossover Frequency: 3.5kHz
Woofer
Speaker Impedance: 2 ohms
Power Handling: 90W RMS, 270W Peak
Sensitivity: 95dB @ 2.83V, 1m
Frequency Response: 45Hz – 25kHz
Mounting Depth: 2-3⁄ 16" (56mm)
Cutout Diameter: 5" (127mm)
Thanks for taking the time to read this and for any replies you may have.... Also... Think those are pretty good quality comp. Speakers?
If the cut out on those 6.5"s really is 5" then definately although I think they mixed up the 5.25"s and the 6.5"s so I'm not likely to believe that it actually is 5". Just about all of your 6.5"s land somewhere between 6.1- 6.4 inches and it says maximum is 6.3" so I'm pretty sure you could really get that extra 10th of an inch if you really needed it... since you have to cut them out anyway... just get out the sand paper :)
