Have a cool ride? Then show it off on our website ! All vehicles welcome!
Adidasman159
Posts: 47 Joined: Sat Apr 22, 2006 3:01 pm
Post
by Adidasman159 » Sat May 13, 2006 11:15 am
ok so evenutally i am going to need new subs for my car, and then put the ones i have in my car now into the new mustang
so i was looking at this sub
http://cgi.ebay.com/DIAMOND-D912D4-CAR- ... dZViewItem
Now i was also looking at this amp
http://cgi.ebay.com/JL-Audio-e1800D-Cla ... dZViewItem
Would this amp be powerful enough to power this sub to full potential
# Rated Power 12.5 V: 480 W RMS x 1 @ 4 ohm
# 800 W RMS x 1 @ 2 ohm
# Rated Power 14.5 V: 640 W RMS x 1 @ 4 ohm
# 1000 W RMS x 1 @ 2 ohm
that is what confuses me
I have a chevy cavalier that they would be going into what one of those RMS numbers would i be looking at the 480 At 4ohm's or like the 1000 at 2ohm
joeyc
Posts: 1703 Joined: Sun Dec 11, 2005 1:15 pm
Post
by joeyc » Sat May 13, 2006 11:41 am
with that sub you would be wiring it to 2-ohms. you need to check your voltage to see how many whats you would be getting, but its probably going to be close to 1000 watts
JC's Customs
Posts: 2329 Joined: Sat Jan 15, 2005 4:13 am
Post
by JeremyC » Sat May 13, 2006 1:12 pm
JL is saying,
The lower ohm load you run it the more power the amp can make.
AND
The more power (voltage) you give the JL to work with, the more power (watts) it can make.
Both are normal of unregulated power supplies.
Steven
Posts: 55 Joined: Sat Mar 25, 2006 4:25 pm
Post
by Steven » Sat May 13, 2006 2:42 pm
Well, i was trying to download a picure of my subs but i can't do it. I have 2 pioneer subs, DVC. They are wired + from amp to + on 1st sub to second + on 1st sub. Then from 2nd + it gos to - on 1st sub then to 2nd - then to 2nd sub 1st + then to 2nd +, then to 1st - then to 2nd - then back to amp - . Anyone know if this is a 2 ohm load or what load it is, thanks, Steve.
joeyc
Post
by joeyc » Sat May 13, 2006 3:28 pm
is it something like this?
http://www.rockfordfosgate.com/rftech/w ... C_1ohm.gif
and it depends on whether or not the sub is dual 4ohm or dual 2ohm
JC's Customs
Steven
Post
by Steven » Sat May 13, 2006 5:30 pm
No, it go's + to + to - to - to + to + to - to -
Steven
Post
by Steven » Sat May 13, 2006 5:43 pm
Joey, i just sent you an mail with an attachment of how it is wired. Thanks, Steve
Posts: 1654 Joined: Fri Oct 15, 2004 11:00 am
Post
by ridr4lif » Sat May 13, 2006 7:15 pm
Dude...what is the voice coil configuration on your subs? Dual 2 ohm or dual 4 ohm? Also, what amp are you running and is it stable to 2 ohms?
Steven
Post
by Steven » Sat May 13, 2006 7:40 pm
They are dual 4ohm. When i bought them i was running an older fosgate amp and the guy where i bought them told me to wire it up this way, which i think might be 2 ohm. Now i have a PPI A1200 and it is only 4 ohm stable.
