What else do i need?
Im getting my 2 channel amp, Bridged mono installed, and a capacitator. What other things do i need? Here is what i got so far. 4 ga. / 20 ft. clear Red Power Cable
4 ga. / 3 ft. clear Black Ground Cable
12 ga. / 33 ft. clear Speaker Cable
17 ft. Blue Turn On Cable
17 ft. Shielded Clear Blue RCA Cable
AGU Fuse Holder with 60A AGU Fuse
What extra wires do i need to wire a 2 channel amp and capacitator?
Its a 1998 Plymouth breeze just so you no.
Thanks alot for the help!
You shouldnt need anything else. Maybe just ring connectors to hook up to battery terminals and to attatch your ground to.
How big is the amp you are running? Are you sure you need a capacitor? You would be better off running a high output alternator. Might also want to upgrade your battery if you havent already.
- Chris from Washington
