Install problems
Install problems
Hi,
I have recently bought a dash kit for my 97 ford escort and have installed it. Now, I just bought a dual deck and have wired it and everything but the deck wont power up. I know the deck has power because the reset button behind the faceplate blinks. The installation manual says to hit the button besides the reset button to reset the system. I do that, but the reset light still blinks. The instructional manual for installation says nothing more to do about the situation and I have no clue on where to go from here. Any help would be greatly appreciated.
Carl
Carl
- Chris from Washington
The dash kit I bought was made by schosche, and that came with the adapter kit. Then from there, I just matched the colors of the wires and plugged the ends in. Then, I tried to turn it on and it didn't work... I originally blew the fuse for the dash, but I replaced that and now all the fuses are good, even the one in the deck itself. The deck is produced by Dual. As for a wire adapter... what is it? and what does it do?
Thanks,
Carl
Thanks,
Carl
Is that a used, or new deck? Not to be rude, but if new. I would take it back, and look into a more reliable HU. I would double check your wires. Make sure you have your power wire(should be yellow) hooked up right. Maybe you have that and the ACC wire crossed.
http://www.sfxaudio.com/AudioSchool/colorcodes.asp
That will give you the colors of which wires are what if you are a lil confused.
