Popping Sound in speakers...
dveeg
Post by dveeg »
I'm having a weird problem. When i press on or let off of the break i get a light popping noise from my speakers. Any input or advice on what it could be or how to solve it would be appreciated.
Thanks alot
Check all your wiring, make sure no wires are being pinched when you step on the brake.
6three6mafia6
Post by 6three6mafia6 »
i used to get that a small popping noice when i would brake, i could only hear when the music was off, dosent happened anymore, probably cause of stuff that was moved during some new installs wich uncluded a clarion HU from a panasonic.
Warbleed
Post by Warbleed »
You probably have a bad ground. I'd check the amplifier and head unit grounds. The factory HU grounds are notorious for being terrible.
carlos
Post by carlos »
Check, some times if your amp isnt shielded enough it can happen, i get static cause i was too lazy to find my cars internal amp so i dont have one shielded and i get static
Dont really care, at the volume I listen i cant hear it unless the music is way down or off
