Looking for specs on the sx15 so i can use this software. If anyone has any of the following specs it would be appreciated
Speaker Parameters
-Qts:_____
-Qes:_____
-Fs:_____ hz
-Vas:_____ liters
-Pmax:_____
-Diameter:_____ cm
-xmax:_____ mm
-Dp:_____ cm
Alignment
_SBB4,QB3, or SC4
RE sx15
Fs 27.8audiobass10 wrote:Looking for specs on the sx15 so i can use this software. If anyone has any of the following specs it would be appreciated
Speaker Parameters
-Qts:_____
-Qes:_____
-Fs:_____ hz
-Vas:_____ liters
-Pmax:_____
-Diameter:_____ cm
-xmax:_____ mm
-Dp:_____ cm
Alignment
_SBB4,QB3, or SC4
Qms 4.7
Qes 0.38
Qts 0.35
Mms 266g
Vas 159 L
SPL 90.4dB@1w
Sd 760cm^2 (1/3 surround value, they're pretty generous in their estimates)
Xmax 21mm
Pe: 1000w (Just put that for Pmax)
I wouldn't worry about specific alignments, I'd just use the one that best fits the power and response that you desire...
