problem with subs
problem with subs
i have 2-12" memphis 3124D subwoofers (DVC) that arent as loud as they should be. one of my friends has some and they are extremely loud. Im not sure if my amp isnt powering them right or what but if all else fails im just going to get a memphis 1000D amp.
My amp is a Sony XM-SD51X
Mono car subwoofer amplifier (Class D)
1100 watts max power.
250 watts x 1 RMS into 4 Ohms
my subs are wired at 4 ohms and the max is 300rms
my friend has a different amp with the same specs as mine but his subs are so much louder. anyone know what might be wrong?
Its the amp.
This is that night and day difference between cheap vs. quality equipment you will see mentioned throughout this forum.
Box can be part of it. Also different vehicle=different acoustics. But I think 90% of it is the amp.
Them Sony amps are world renowned for being crap
even if your friend had the same amp you can expect different results unless everything else were identical..enclosure,wiring,head unit, rca's and even the car...your car will have an effect on how your speakers play because of the cars interior shape this is called cabin gain..your vehicles layout naturally effects certain frequencies differently than other cars will by naturally boosting some areas....
i was told to wire them at series parallel and i looked at a few diagrams so im sure i wired them right, but they dont sound any different than when i had them wired just regularly.
My head unit is a this JVC if it makes any difference http://www.jvc.com/product.jsp?modelId= ... =54&page=1
The box is 1.25 cf per chamber and i think thats the recommended for sealed boxes but im thinkin im going to get a ported box.
My friend with the same subs also has that memphis amp i want to get- so that might be the problem. The stats are the same on both amps but i guess the sony just doesnt power the subs as good as the memphis.
and just out of curiosity.... are there any differences between wires/amp wiring kits or can i just buy the walmart brand and get the same outcome?
depends on who you ask. http://www.knukonceptz.com/ makes decent, low cost wiring kits.
definitely the amp. possibly the enclosure, too.
If you want more SPL, and better sound overall, I'd suggest getting a much better amplifier (read: NOT Sony) and go to a ported box, about 2cu ft per 12" sub, with 4" or slot-vent ports tuned to about 34Hz.
you'll get much better results. Like night and day.
