Six channel Impedance Help
inetba
Post by inetba »
I've tried searching this site and google, I'm looking at getting this six channel amp.
http://www.woofersetc.com/p9183/LRx-69- ... lifier.htm
I'm looking for a one amp solution and I need 4 channels at close to 130 watts RMS for the front and 2 channels at around 250 watts RMS for the rear and this is the closest I have found.
All six speakers are 4 ohm impedance and it mentions: "RMS Power @13.8V @2/1 ohm 4 x 120 watts + 2 x 230 watts"
What I wanted to know is how would I wire the 4 front speakers to 2 ohms to those 4 channels and how would I wire the back 2 at 1 ohm for the other 2 channels.
I've found subwoofer wiring diagrams but no speaker wiring diagrams.
Edit, I found a much less complicated solution, I just need to know on a four channel amp can you have 2 channels running a 2ohm load and 1 channel running a 4 ohm load or will that break it?
This is the amp in question: http://www.woofersetc.com/p6852/SE-4200 ... lifier.htm
Am i the only one who cant see anything?
Now try. Appears some how the approve new posts was turned on. So the OP had to have his post approved.
Nope
OnYrMrk
Post by OnYrMrk »
Other than the OP getting the amp wrong, this is a 4 channel amp, I don't see any issue. To the OP, I would suggest running an Audison LRX5.1 for your system. It is truly a one stop shop. 4 channels for front and rears, and 1 channel for sub(s)
inetba wrote:I've tried searching this site and google, I'm looking at getting this six channel amp.
There ya go Bill
