will these fit in the rear deck of a 03 grand am
colemanyoungerinalaska
with the stock covers
if not what will
http://www.cadencestore.com/ProductCart ... roduct=433
http://www.woofersetc.com/p3077/CL69--C ... woofer.htm
if not what will
The grand am is just like an Alero.
You will have to pull the rear plastic panels to pull the rear deck card. The 6x9's are mounted in plastic adapters that simply clip to the rear decks metal.
Do you need just mid bass or going for a subless setup just using 6x9's?
For sub-bass:
4 Ohm
http://www.parts-express.com/pe/showdet ... er=264-864
8 ohm
http://www.parts-express.com/pe/showdet ... er=264-837
Please note that on the Alero board someone bought these 6x9s. They are larger than the stock ones, so you will have to grind away some plastic to make them fit.
For sub-bass:
4 Ohm
8 ohm
