Do round ports have to be straight?
Can round ports be angled (90 degrees) so they can fit in an enclosure? Will this create different dynamics inside the enclosure than a straight port? I used a few programs to calculate a port diameter/length (for round port) for one JL Audio 10" 300W sub with 1 cu. ft. enclosure @ 31 Hz tuning frequency (per JL Audio manual) and the port length came out fairly long (16"-19") compared to enclosure dimensions (~16"x13"x9"). If I could use a port at a 90 degree bend it would work well.
Perfectly fine and normal.
Do it all the time with slot ports.
In many cases you have to have a turn in the port to get to proper length for tuning... as long as it is secured well so it gets no vibration then you won't notice.
The biggest issue is to make sure that the port is not obstructed by the sub(s), I try to keep the distance of at least 1 inch away from the back of the sub as many subs nowadays have vent poles on the back for cooling... Basically the same rules as applied for the back wall of the enclosure.
- MobileAudio219
