Help with setting up 4 ch
Post by CaptainPioneer »
Alright I have everything set on my Amp... all wires are perfect and ground is less than 2 ft and clean.
I want to go ahead and power all my speakers now from my new Autotek sm4-1000 but i have some questions. The amp was provided with that highpass conector... Should I use that? I never have before, although the last time I wired up a 4 ch for my speakers it sounded like POOP...
Im hoping that the sq will be much better this time coming from an Autotek
I am getting the source directly from the HU via some nice shielded JL Audio cord and then bridging that over to my sub amp (Hifonics Brutus 1605D) Anything I should be conscerned with?
BTW the HU is a new Alpine iDA-X200
COR UNUM VIA UNA - Jay Chmura
The highpass? are you using the RCA or the highpass inputs.
RCA: Speaking of which should i send 2 sets to the Amp?
Yes. there is no need for the High-pass inputs if your using RCA's you want all four RCA's Driver front driver rear passenger front and passenger rear.
Ok i'll have to buy another chord
falkenbd
Post by falkenbd »
I personally only use Front and sub. Needing rear RCAs is install dependent.
falkenbd wrote:I personally only use Front and sub. Needing rear RCAs is install dependent.
if you want to fade then you do.
falkenbd
Post by falkenbd »
Bwcad1 wrote:if you want to fade then you do.
Which is why I said install specific. (Can't fade with no rears)
What exactly are you powering with your 4 channel amp?
EDIT: after re-reading your post it sounds like you are powering 4 sets of speakers inside your car. so yes if you want to power the rears and fade them you need 4 channels of RCA
Another thing I noticed is, that deck has SUB out as well. SO - you COULD use 3 sets of RCAs (or a 2 ch and 4 ch) so you can control your sub level from the deck, and possibly crossover between sub and speakers as well (not sure what that deck has)
I think I am going to actually buy 2 more sets of RCA wires for this, Originally I was jumping the signal from my sub-out to my 4ch but instead i think I will go independent now instead of jumping...
I don't really need to fade though as the speakers are in such close proximity to each other but who knows maybe when i transfer all this stuff over to my other car next year I will have that need
Daisy chaining isn't a good idea its a serious loss in quality. use all 3 sets of rca's do it the right way in the beginning.
