great! now my headunit is broken!
brisgreat1
brisgreat1
brisgreat1
brisgreat1
Take the radio out of the car. Pop the hood.
Put the ground on the batteries ground, put the yellow and the red on the batteries positive.
If your radio does not work at that point, its messed up or blown fuse...?
brisgreat1
head unit works, i did that a few times already. my backup fuse under my hood was blown, a 7.5a fuse. i replaced that, the fuses under the drivers side are all at least in working condition. i need to get a volt meter i guess to check my acc, power and ground wire feeds i guess. i dont know how to use a volt meter, is there anything to it? also what else could my problem be if its not the fuses, just the wire leads? I'm 100% its NOT the head unit.
Unless you messed up the ground somehow.
Try putting the 12VS and 12VC on the harness and striking the ground on something close by just to see if that it...
I'd have wired it up to a direct 12V, ignition lead (ACC), and ground and called it a day by now
