Help deciding on amp for subs
I think you need to cool your jets.
I wasnt a dick to you and your not going to be a dick to me.
Consider that fair warning.
Its not nearly as flexible as copper.Bwcad1 wrote:Its so inflexible i was able to wire 8 amps so tight next to the amp you cant even see the wire.
PM me your addy. I will send you what I got left.
Se if its as flexible as the stuff you got. Maybe they revamped it some?
Aluminum isnt as soft of a metal as copper.
The jacket maybe stiffer also.
At any rate its not as flexible as the copper. At least the stuff I have.
callandor2k
- Member
Bwcad1 wrote:As far as the battery question, the shuriken battery is designed as a secondary battery its not a normal starting battery. Its not a capacitor its still a battery just different just like a yellow top and red top from optima. If you put a kinetic under the hood you would probably be fine. I for one always like to put my batteries as close to the source as possible and adding a second battery works great. I still say add a second battery like the kinetic 600 or shuriken. For fusing you will need to fuse that wire at the back battery as well.
Ya after I went to bed I realized I would need 2 fuses on the main line. 1 on each end of the wire to protect both batteries. I think I am just gonna go with a Shuriken for now. And if I ever need a new main battery I'll go Kinetik then. And still use the Shuriken in the trunk. Now I just gotta figure out where to put the battery. The sub box takes up 1/3 of my trunk (give or take a little). May have enough room beside the box to make a small box for it to set in.
Oh which reminds me. Since mounting amps on the back or top of sub boxes is not a good idea. What about mounting them upside down on the bottom side of the rear deck between my rear speakers?
Ryan from Ohio wrote:Its not nearly as flexible as copper.
odd...
Brinell hardness of 3003 Aluminum (most common for wire) 28-40 depending on temper.
Brinell hardness of 110 Copper (most common for wire) 40-44 depending on temper.
odd but true.
I dug it out of the drawer. I got about 1' of it left. The rest went in the Saturn- thought I pulled it but didnt.
It does flex and move but not near as easy as the IOXS copper stuff I have (also from my drawer stash).
Another thing it does, which I forgot about. After cutting it and messing with it, the core bundles in the center worked out of one side a bit.
Again, the copper wire doesnt do that...
The picture sucks, but shows what its doing.
- Attachments
- 100_6253.JPG (239.04 KiB) Viewed 596 times
callandor2k
- Member
