Overall Car Audio Security
OnYrMrk
Post by OnYrMrk »
I have a sweet rubber band gun that is a true six shooter! Don't mess with me, I have a welt with your name on it!
Post by CaptainPioneer »
yea those things hurt like a bitch! One time i got shot in the eye with one of them... lets never relive that painful experience again
COR UNUM VIA UNA - Jay Chmura
Get a paintball gun... that way you can easily identify the criminal :p
smoker wrote:maybe there is an omega dealer here on the board? :unwell028 i think both mike and i are omega dealers....
Yeah I can get Omega too :)
Geo: I thought about what you said in regards to prevention today at work. It's definitely something I over looked completely.
I should probably take my out my HU, put the OEM back in, and mount it right under the lip of the dash to the right of my steering wheel. It'd be just as easy to remove it from the car then when I park it so that it looks like I'm only using an OEM HU. If anyone has any other ideas for mounting where I could still easily insert CDs, feel free to suggest!
I could take a blanket and stick it over the box and amp rack in the back, but I'm not sure if that would defeat the purpose of prevention. The box is clearly visible from the outside looking in, but you can only see the top amp slightly on the amp rack. When I learn fiber glassing, I'll be able to make the amps sit lower and reduce that problem. I should also be able to minimize the sub problem as well, but it'll still be visible from the outside.
In regards to the alarm, I'm going to keep looking at the Omega, Scytek and other alarms. I would like that remote start with the manual trans bypass, but manual trans remote starts are illegal in my state.
TechSys
Post by TechSys »
The key to an effective security system is to think like a thief. If you can think of a way to get something easily, so can the thief. Work on that area.
Around here thieves like to "work" in the dark. Well, light up the car as much as possible when the alarm goes off. Strobes, underbody lights, blinking headlights, taillights, and parking lights. Make you car light up brighter than a Christmas tree to make it noticeable.
Sirens. Always have an alarm that has backup battery capability. Place a piezo or 2, 3, 4 in the interior (well hidden). Kind of hard to think when you have those things blaring in your ears.
Put things like your amps under thick plexiglass. Basically build an amp rack but have the amps secured with security bolts under the plexiglass.
The more work a thief has to do, the less likely things will be taken. The equipment could be ruined, really isn't anything to do about that if they get past your security system.
Never, ever, use the red or orange LED that comes with most alarms. change them out to a different color. I used to have warns every night, before I changed out the LED. I put 2 very bright blue ones facing out the windshield (one on each A pillar). Haven't had so much as a beep from the alarm since.
Scytek does look like good alarms. I thought about getting one just for the camera capability. Still might..
Darthness
Post by Darthness »
if someone so much as sneezes or looks too hard at my car, i want to know.
- Keith
geolemon
Post by geolemon »
solacedagony wrote:Geo: I thought about what you said in regards to prevention today at work. It's definitely something I over looked completely.
I wouldn't do anything crazy - your stereo is there to enjoy, not to have to become a contortionist to operate it. :D
Also, think like a thief.
If you were a thief, you'd peek into an unfamiliar car to see if there might be clues that there was something inside.
You probably wouldn't walk up to the car 100% predisposed to believe that there WAS something inside - and when you didn't find it, you wouldn't scour every inch of the car interior looking to see if it was somewhere you didn't expect it. ]I could take a blanket and stick it over the box and amp rack in the back, but I'm not sure if that would defeat the purpose of prevention. The box is clearly visible from the outside looking in, but you can only see the top amp slightly on the amp rack. When I learn fiber glassing, I'll be able to make the amps sit lower and reduce that problem. I should also be able to minimize the sub problem as well, but it'll still be visible from the outside.
In regards to the alarm, I'm going to keep looking at the Omega, Scytek and other alarms. I would like that remote start with the manual trans bypass, but manual trans remote starts are illegal in my state.[/QUOTE]
Tint the back window extra dark.
Perfectly legal, as long as you don't do the side windows.
That's cheap and effective.
Darthness
Post by Darthness »
tint is my plan for my truck... i want extra dark on the back, and the rear windows, and the front/door windows will be around 20%.
and an alarm. deck relocation isn't a bad idea... except for wiring. another idea would be if you went the car pc route... you could mount the screen in the head rest or something... with a slot load cd drive and a few usb ports or something in the dash..
or with the car pc... you could even mold the screen into the dash.. just make it hard to see or something
- Keith
i put a head unit into an 87 camaro once and the guy asked me to make acover for it so i took the factory cassette head unit and took the face off, then i cut a cassette in half and glued it into place so it looked like it was sticking out of the head unit......then all he had to do was to pop off his detachable faceplate and stick that over the aftermarket head unit.....it wasnt perfect but at a glance you didnt notice something was afoot..........
