subs w/ amp
atlbravesfalcs7
Post by atlbravesfalcs7 »
Bwcad1 wrote:Just do what i told you a bunch of posts ago. forget the math. If this is stressing you out stop ****ing with it and take it to a pro. For a few bucks they will set it up correctly and you wont have to stress.
well, i think i can figure it out. as long as that math up there is correct then i shouldnt have a problem setting the gain with the dmm im going to buy tomorrow. ive watched videos now and understand exactly how to do it. i just need to make sure that im setting it to the right level, thats all.
I still disagree with setting the amps via that method but whatever floats your boat.
atlbravesfalcs7
well im only setting the gain this way i will fine tune differently. but is that math correct?
atlbravesfalcs7 wrote:well im only setting the gain this way i will fine tune differently. but is that math correct?
If you followed the directions it should be correct then.
atlbravesfalcs7
Ryan from Ohio wrote:If you followed the directions it should be correct then.
do you factor into the math how many subs you have, or does it not matter since it is separated by 2 different channels?
Your load is your final load. that means the amount of subs doesnt matter as long as its factored into your load.
The final value you found is what you adjust your gain to until you see that voltage number on your DMM.
atlbravesfalcs7
Ryan from Ohio wrote:The final value you found is what you adjust your gain to until you see that voltage number on your DMM.
so even tho im powering 2 subs into the amp, both at four ohms, its still 220 rms x 4 ohms, then square root of that. correct??
i will tell you guys how it went when i do this tomorrow. thanks for all the help along the way. this should have been done a long time ago.
Yuppers.
Because your only looking at one channel here.
