Hifonics BXI2607D?
loudwagon15s
because most people are idiots and don't understand amps and electricity.
Its just as easy to do it with both amps as it does strapping.
Wire the subs in series
so each is 4 ohm.
Take one piece of wire (single piece) connect the negative of one coil to the positivie of the other. then take a piece of wire and wire the positive and negative left over. check with DMM should read 4ohm.
do the same for the other sub.
take both sets of wire that are coming out of the box and connect both positives to one amp and both negatives to the other.
so each is 4 ohm.
does it matter which amp I connect the pos. and neg. wires to? I know when I strapped the US Amps I connected the pos. to the master amp pos. terminal and I connected the neg. to the slave amp pos. terminal. Do I have to do the same with these amps. And I am not an idiot and i understand how to set my amps individually I just want to know how to strap it so I have options.
I am not risking my equipment and never have, that is why I consult with people before I do anything I do not understand, and no the users manual for the BXI2607 does not discuss where and how to run your subs when they are wired like mine. It only has a diagram of a wire coming off of each terminal, 2 pos. and 2 neg. I only has 1 neg. and 1 pos. coming off of a sub.
Ok I want to wire a sub to each amp but I do not want to have to gain match both amps, I only want to set the gains on one amp. However, I do not want to strap them, is there a way that I can wire a sub to each amp and still be able to only have to set one amp without strapping them. If there is a way for me to do this can you tell me how? Also I just got my amp replaced so I am wondering how much more power should I see running 2 of these at 1 ohm a piece compared to 1 at .5 ohm?
