i have a problem..rca's?
i will pull it out and take a look at them...but i dunno if that would affect it.Scarrell wrote:you know when you buy an adapter for your cd player.. the factory wires have them little metal things at the end that slide into the factory adapter. maybe some of them are damaged or something..
speakerman - i dont know if you mean outside the doors literally or just other speakers :P if you mean it literally no, but I did hook up some small 3" speakers and i had the same problem, one output was larger than other.
I will end up taking it to a shop if the problem pertains when i re-do my install in a couple weeks, gonna mount the x-overs in the trunk which should solve my noise problem cause i think its by some wires in the door (dunno for sure).
anyways i think ill just ship my car to the get-together so you guys can look at it
kevinberry1
I just thought of one more thing to ask. Did you run the power wire (from your battery) along side the RCA's to the amp? Sometimes this will cause interference and create unexpected problems. Not sure if this is the case, but just thought I would ask. Good luck and I hope you find a solution soon. I know from personal experience just how frustrating these problems can be
I blew two Diamond subs last year and couldn't figure out why until I removed the magnet covers and realized that the guy had sold me the wrong model numbers and I gave them twice their recommended wattage. Boy did they hit hard for 2 days though :)
Keep us updated!!
Keep us updated!!
[quote="lotas"]i will pull it out and take a look at them...but i dunno if that would affect it.
anyways i think ill just ship my car to the get-together so you guys can look at it ]
did you disconnect the door speakers when you tried the 3" speakers? Or was everything hooked up?
THe only thing you can really do now is swap for another amp, or swap your amp into someone elses car. That will let you know 100% what the problem is.
uhm all the wires were still ran to them but the xover ---> amp was unplugged.spkrman wrote:did you disconnect the door speakers when you tried the 3" speakers? Or was everything hooked up?
and kevin, the rcas for that amp are run down the center console of the car, the 12v wire is run down the left side, so they are about 2feet away.
i will try the amp swapping and see if i get some luck
