Haha, my blazer gets around 18-20 in town and 23-24 on the highway....
With the v8 it'll probably get around 15-17 highway and around 10 around town...
Your car should be able to oull around 30+ on the highway...
Car overheated and was steaming at idle
- MobileAudio219
Mithrandir
- MobileAudio219
Try unplugging the TCC solenoid... Does the car want to stall when you're stopped in gear? Does it run fine when its in park/neutrual?
Didnt you just change your tranny fluid? If so, how did the old fluid look/smell?
Have you checked your fluid level lately?
Mithrandir
Old fluid looked and smelled fine there was a bit more metal powder in the pan than should have been. Fluid is full and yes if I unplug the solenoid it runs fine.MobileAudio219 wrote:Try unplugging the TCC solenoid... Does the car want to stall when you're stopped in gear? Does it run fine when its in park/neutrual?
Never had a problem with it stalling at all, and it seems to run fine in park/neutral except sometime is sputters until i rev the engine, then its fine again but its never been an extreme problem, just slightly annoying. As for the shaking that is a pain in the ass so if its the solenoid and i can get someone to replace it for like 400 bucks ill do it.
The only other problem i noticed is the car seems to be running rich.
It was running lean before I replaced the fuel filter (o2 sensor was white). I have to check it again and see if its black. Im wondering if adding a cool air intake and maybe exhaust will solve this.
