Which amp for my Atlas 12 and fronts?
NaughtyTegRoc
- Member
NaughtyTegRoc
- Member
I like the WOT section, very comical.
Plus I get to let it all hang out and be a prick for the fun of it
I even defended ya over ther Teg...
BTW Whats ur name so we can quit calling you Teg?
On Topic
This is my sugguestion for an amp:
http://www.cardomain.com/item/JBLGTO7556Z
Due to your door speaker requiring such little RMS its impossible to find a 4 channel amp that will do 50 WRMS @4 Ohmsx2 and 300 WRMS @4 Ohmsx1
This amp will give rated power to both front channels and to the subwoofer. You will have two channels leftover you can utilize on rear fill or get creative and add a second set of fronts.
On Topic
NaughtyTegRoc
- Member
Your fronts are fine. What Im trying to say is its next to impossible to find a 4 channel amp that will poer your setup like it needs to be.
This JBL Amp gives the needed RMS to all comps and its inexpensive. It is refurbed, but my experience with refurbs is this:
If large numbers are refurbed then there is a potential design flaw or possible batch of bad componets. Refurbs are usually built back to a higher standard and more "beefier" build.
For just a little more than that Lanzar amp also
Hard to beat :)
Hard to beat :)
NaughtyTegRoc
- Member
They must of updated that page today...
