subs w/ amp
atlbravesfalcs7 wrote:ok so i adjusted it at the settings above, i did not use the ddm yet but put the level on the amplifier up past halfway, and it still seems like the bass isn't hitting nearly as hard as it should. also, the front right speaker is making a bit of a scratchy noise at times during the music.
then your distoring the front speakers back the gain down some.
follow these intstructions and you should be fine.
Set your HU to 3/4 volume. adjust the gain till you get the maximum output WITHOUT DISTORTION adjust till you hit distortion then back off slightly. IF they make any noise other than what there intended to (Subs = Bass) (Speakers = Full range) turn the gain back down some.
atlbravesfalcs7
Post by atlbravesfalcs7 »
but the amp is only controlling the subwoofer, its not controlling the speakers. and im pretty sure 3/4 volume will distort my speakers pretty badly.
atlbravesfalcs7
for example, my regular speakers have a range of 0-35 on my head unit, and they are powered by the amp on the head unit. if i go past 16 on my head unit, they will start to distort badly.
Then you tune the amp from 35 then.
Its all relative.
atlbravesfalcs7
well how do i tune the amp in my head unit so i can play the music at ranges at 25-26 volume instead of 16 being the highest? i think the problem is that my subwoofer wants to have its maximum power at around those levels (25 26) while my speakers wont go above 15 without distorting.
I misread it.
If your speakers distort after 16, then set it to 16 and tune the amplifier.
atlbravesfalcs7
Ryan from Ohio wrote:I misread it.
ok, so would it be normal to have the amplifier having a gain of over 50%?
it seems kind of high. another problem may be that the ipod i have connected has a certain equalizer. would that also affect it?
atlbravesfalcs7
and can someone verify this? sorry but this is starting to stress me out.
my amp says that at 4 ohms, its 220 rms. and i will be powering 2 alpine s 1223D subwoofers both at 4 ohms in the two channels.
so first i should multiply 220x4=880 and then square root of 880 = 29.66. does that seem right?
atlbravesfalcs7 wrote:ok, so would it be normal to have the amplifier having a gain of over 50%?
Its all based on what your head unit output voltage is. They can be anywhere on the dial.
atlbravesfalcs7 wrote:and can someone verify this? sorry but this is starting to stress me out.
Just do what i told you a bunch of posts ago. forget the math. If this is stressing you out stop ****ing with it and take it to a pro. For a few bucks they will set it up correctly and you wont have to stress.
