Autotek MM2000.1D
- swimmerdude
The MM2000 would still be a lil over the $500 dollar mark through one of us... Might I make some other suggestions, like the Xsite XAD2K (does 2000wrms @ 1 ohm) or the Audiopipe AP30001D (does 3000wrms @ 1 ohm) and both can be had for between $400-500, and you get the full warranty, both are very good amps and and will do rated power, a step above some of your lower level brands
Audiopipes are CEA approved... so I wouldn't lay any bets
Although I admit that they are rated at 14.4
Yes they are actually rated at 3000watts rms
are you talking about the GD3001? i cant find anything with an amp rated at 3000RMS. there is no way your getting an amp that produces that much power for that price. u just cant do the components needed to do it are drasticly more exp than a 1000 watt amp.
GD3001
Features:
* Max Power: 2000 Watts
* Fully 1 Ohm Stable
* Variable Low Pass Electronic Crossover
* Variable Subsonic Filter
* Parallel Speaker Output
* Terminal Allows Use of 4 Gauge Power Cable
* Master/Slave Allows 2 Amps to be Linked for Maximum Power Output
* Built-in Variable Phase Shift
* 60mm(H) x 295mm(W) x 380mm(L)
there largest amp
Audiopipe Class-D Professional Mono Amplifier (GD-6001)
Features:
* Max Power: 4000 Watts
* Terminal Allows Use of 0 Gauge Power Cable
* 60mm(H) x 295mm(W) x 550mm(L)
Specifications:
* Distortion: <0.5% THD
* Signal to Noise Ratio: 60dB
* RCA Input Sensitivity: 0.2-5V
* Input Impedance: 20k Ohms
* Low Pass Filter: 40-250Hz / 24dB Oct
* Subsonic Filter: 10-50Hz / 24dB Oct
* Frequency Response: 10-300Hz
* Master/Slave Output Power (RMS): 4000W @ 4 Ohms
* Output Power (RMS):
* 600W @ 4 Ohms
* 1100W @ 2 Ohms
* 2000W @ 1 Ohm
GD3001
Features:
there largest amp
Features:
Specifications:
* 600W @ 4 Ohms
* 1100W @ 2 Ohms
* 2000W @ 1 Ohm
And keep in mind Bill, I never said that they were "as good as" Autotek MMs (higher end), I only stated that they are a step above lower end equipment
That's last years model...
This is the new AP3001D:
http://www.audiopipe.com/AudioPipeCatalogOne.asp?Picture=AP-24.jpg
