That sucks. Those studs just hammer in and out don't they? Do you have to take off the entire spindle to get them in and out?cargodz wrote:I got your message this morning when I got up...
You do know this is a build, not a comp... right?
The first comp it will be attending will be in January in Indiana :)
That's why we're tryin to get everything big done now... so I still have time to wrap up odds and ends before the comp....
Speaking of odds & ends... I went to get the back wheels off and broke 2 studs and may end up breaking more... so it looks like I got some more small things to deal with along with the back brakes.
Bill's extended Build Update
If you need mike, get them spindles pulled off.
I can press the studs out the backside at work with the hydraulic press.
If you need that done by the weekend get them sumbitches off for me on Thursday, will pick them up.
ZeroAccess
I gotta install an alarm today and a few odds and ends, but should be able to get to it today.
ZeroAccess
I broke 4 of them studs on the passenger side back... and yes they are pressed in....sledge doesn't do a thingRyan from Ohio wrote:If you need mike, get them spindles pulled off.
The spindle is off from the passenger side though, so were good to go for Ryan to get them punched out
The drivers side I managed to get free'd by myself... so were good to go there :)
