bad ground at head unit, or the amp gain is set too high, most likely.NViejeP wrote:Omg! I get a noise like this.
Its like a high-pitched whistling/squeling sound. As I rev or accelerate it gets louder. When I have just the radio on without the engine, the sound is gone. It kind of sounds like its coming from the tweeter, but it could be from th event. When I have the radio low, the sound is there.
I'm thinking that it could be air coming in from a hole somewhere, maybe from the hole they had to drill to run the wire?
This started happening after I got my amp + speakers installed.
Anyone know what is it? Unlike the poster, I dont have the sound when I have the power, but not the engine on, so it is kind of different.
Teh Noise
amps are in my first post but Alpine MRP-F240 and Hifonics TX1005DAirforceyooper wrote:Alternator whine. There's a book written about it. I've got that book. :) lol.
How high quality RCAs are you using? How far away from any main power sources are they? Amp power wire? Fuse box area? Etc.?
Is your head unit grounded well? Is your amp grounded well?
Is your car battery in good shape?
What amp are you using?
Ground should be well but im going to make sure everything is good at my ground distrobution block.
RCA's are ran with the power wire... but i'm going to change that in a few weeks when i get the time to tear my car apart.
HU Ground? lol. if circuit city grounds it.. i guess it is. i figure its probably hooked up to the supplied "negative" wire. Battery should be fine...
edit: i'll check the gain on the amp in a few minuets here.
As for grounding the head unit, do i just solder it to the cage or what? i've never really done that before
- Keith
Robert Wollenberg
My first guess would be the RCA being along side the power wire. Especially if you don't have high quality RCAs. Also, as Glass Wolf mentioned, the gains on the amplifier. Just because CC did the deck install, doens't mean it's done right. Their electrical tape might have gotten hot and sweaty and slid down the wire or something and the wires have come undone. lol. Just kidding. CC better not have used electrical tape.
Robert Wollenberg
Robert Wollenberg
Robert Wollenberg
