thanks guys.....and yea that is a little trunk...box is 1.77 internally but it is 1.5" thick front and back with extra bracing that ties the top and sides together and it is built like a tank...it was cut, glued, nailed and screwed then sealed inside and out....the hole was cut close to size and then rasped to a perfect fit and all the edges were rasped flat and smooth on the outside so the carpet would be as smooth as possible....you couldnt feel a joint in the wood anywhere on the outside.....and seriously with around 1500 watts or so it gets...REALLY loud and sounds excellent doing it....
i just wish we had been able to recarpet the whole trunk because it actually wedges in real tight...but it was money he didnt really have....
