System Suggestions
NViejeP
Post by NViejeP »
Wow Jonathan, aprpeciate your effort in trying to help.
What I was thinking is that, at first I can get the subs installed with 2x RE RE10 with a KX 350.2 refurbished pushing it.
As I get some more money, I will get another KX 350.2 if it turns out well, and use those to push my front components whihc will probably be some CDT CL-61a.
What you guys think? Oh and Jonathan I did some research on taht 550.3 but it seems kind of shady to me. I think im still preferring to go with the 350.2.
Suit yourself, the 550.3 is a great amp for pushing a whole system, though. That's a route we went a lot when we were putting systems together for under $1000, and it worked great.
I'd still recommend getting the one better sub, and possibly a Class D mono amp. Maybe a 12" sub instead of a 10". Get one that will present a 4 ohm load to the sub, and if you want to upgrade later you can just wire another sub to the amp at 2 ohm to double the power.
NViejeP
Post by NViejeP »
Hum.. That 550.3 is kind of appealing to me.
Sorry for asking for a lot of information, but what are the exact RMS breakdwons in 4 ohm and 2 ohm?
What is your recommend sub and 6.5 component speakers for the 550.3? thanks a lot I apprecatie it greatly.
14.4V:
70 watts x 2 chan. @ 4 ohms
85 watts x 2 chan. @ 2 ohms
Sub Power:
210 watts x 1 chan. @ 4 ohms
420 watts x 1 chan. @ 2 ohms
12.5V:
40 watts x 2 chan. @ 4 ohms
70 watts x 2 chan. @ 2 ohms
Sub Power:
180 watts x 1 chan. @ 4 ohms
360 watts x 1 chan. @ 2 ohms
Thats the breakdown. Keep in mind, you're gonna wanna change your sub selection if getting this amp. Do what jon said and run a single 12.
here's a link to that amp on sonic electronix.
http://www.sonicelectronix.com/item_3586.html
Edit: this sub would sound good on that amp running at 2 ohms
http://www.sonicelectronix.com/item_5527.html
NViejeP
Post by NViejeP »
Would I be running it at 14.4v or 12.5v? Or can I choose? Does it matter on my car or something?
Well, 12.5 is what a batteries voltage is when just sitting there. 14.4 volts is what some cars charge at. Most cars charge between 13.6 and 14.4 volts.
Team AI
Post by Team AI »
Just in case you were still thinking of going refurb to save some money http://www.hifisoundconnection.com/Shop ... /SFV/30046
I know it may seem I'm pushing these guys but I'm really not I just know they have really good prices and am trying to help you stay on a budget and free up money for a higher end front stage so just let me know if it's getting annoying. I know what it's like to be on a budget with three kids :P
It would be somewhere in-between. Most alternators will be in the mid 13s as far as voltage goes. The amp itself is underrated, you'll usually get around 70W RMS x 2 on the front channels from realistic voltage levels, same goes for the subwoofer section.
NViejeP
Post by NViejeP »
I'm probably going with a refurbished kx550.3 - Going with the math and stuff, I realized that I'll be paying like $125 extra just for the install + wires of the 2nd amp. So why not just go with 1 amp?
Just need to find a good sub for it.
NViejeP
Post by NViejeP »
Me and Ridr4lif were talking. And heres what we've got so far for the sub:
MB QUART DWF304 Dual 4 Ohm Voice coil $67 SHIPPED ON Ebay!
Diamond Audio D312D4 Dual 4 Ohm Voice coil $110 SHIPPED on Ebay!
Both are brand new. Which one would you choose or do you have another suggestion?
