blowing an alternator
BASSic_designs
i am picky on amps
i am more picky on my amps than my subs i am pretty loyal to crossfire amps......since day one, they have always been rated [email protected] volts ex.....the vr1000d 's which are the ones i have put out atleast 1,000-1,200 watts each.....i also like Crossfire becuz they are very efficient
BASSic_designs
by the way, one reason that i may now have dimming lights, or anything is cuz i very rarely turn the volume on my head unit past 23-25/ i think 40 and may bass level usually stays on -1/ -3 - +3 thats plenty loud enough for me except when i wanna impress sumone, or when sumone rolls up beside me bumpin loud....that waz oart of the reason i wanted to go a lil overkill on this system......would rather have expensive subs+clean amp working at around 20% than low wattage amp working 90% all the time pushing subs to they're max will last much longer in my oppinion
"would rather have expensive subs+clean amp working at around 20% than low wattage amp working 90% all the time pushing subs to they're max will last much longer in my oppinion"
You have a clouded view on how this all works my friend.
The amplifier works no more or less if its a higher powered or lower powered one...
Efficency falls off when you supply less and less voltage...
