Wiring Questions
stephensmia
Post by stephensmia »
its just two power wires. what guage from the batt to the fuse box. and where can I buy one. Also what about a d-block
Robert Wollenberg
Post by Robert Wollenberg »
I second that. Personally, everything in my audio system is wired to my battery.
wait there you lost me. are you going to make your own fuse box? and how many monitors are you running?
stephensmia
Im interested in the fuse box and I'll be running two monitors
i would run 8 or 10 gage to be safe the the fuse box and probably 10/12 to the monitors from the fuse box. i would just build the little fuse box under the dash or something close to that.
stephensmia
For power do you just tap the positive cable from the battery
just add one of the things i listed above its the best way to go!
stephensmia
thanx
just make sure you put it in a place where it is easily accessable in case something blows. if you need any help with it let me know. wiring them can be a little tricky. they run off of a relay and also have a circuit braker, but if you follow the directions you will be ok.
