Bwcad1 wrote:What kind of car is this again? Never cut the factory wires just add more wires. Cutting the wire does nothing for you. Leave it there it cant hurt anything. Add a batter to chassis wire battery to alt wire and chassis to engine wire in 4awg.
It's a 2005 Cavalier LS. Never said anything about cutting the factory wires. Also I know a bit about automotive wiring. 10+ years in the automotive repair industry. So I know what I am doing as far as stock/standard auto wiring goes. It's just this add on stuff. I just wanna do it right. Hence the question...
"So do I still need to upgrade from there" meaning go from 4awg to 2awg. Or just leave it alone.
"or just add a second set of 4awg wires along with the factory one?" self explanatory.
just add it btw I've been installing for quite awhile and never seen a cavy with factory 4 gage. I didn't question ur knowledge relax a bit bro as far as upgrading your wire no we already told you. just add a new 4 gage wire to all the contact points. do not remove any of the factory wire.
Ok thanks for clarifying that. I jut wanted to be sure and to do it right. I'm relaxed just been a very long day.
cmwilson wrote:Don't know if you've made a decision on that amp yet but I'd def. either run with the Alpine or MB, the discus series is seriously underrated. Also, depending on how much of a price crunch you're on, the Crunch GPV 1000.1 is a great amp for the price. Also, I'd run with the Dual 4 ohm Type R's. And as for batteries, check out Shuriken's also.
Been looking for that Crunch GPV 1000.1 but I cannot find it. I can only find the GPV 2000.1 which is 1000w rms and 2000w max. vs the MB Quart at same ratings.
How does it compare the the MB Quart since you all would prefer the MB Quart over the Alpine and MTX?
one thing you will note about car audio is our wires are all larger than the factory sized wires. While it may have a "4 ga" in there compare to a car audio "4 ga" and it will look like a pencil.
callandor2k wrote:What ya mean underrated? You mean it will put out more than it is rated for or that people think it's junk because it isn't BIG name?
MBquart is a big name and it puts out more power than rated.
MB Quart is top shelf stuff. I picked up a set of Quart 6 1/2's for my woman T-Blazer. Cant wait to put them in an see how they sound.
You ran that Discus amp for quite a while didnt you bill.
Tim
Tim Strong http://upscaleaudiodesigns.webs.com/
Email: [email protected]
X-box Live Gamertag:quad drpr
Guess I never really heard of MB Quart. Usually looked into Alpine, Pioneer and JVC before.
Since MB Quart is pretty good stuff what about putting up Alpines SWR-1242D up against MB Quarts PWH 304? Both are rated at 500w rms each. But Alpine is rated at 1500w max where as the MB Q's are rated at 1000w max.
Also since the MB Quart 1000.1 puts out more than what it is rated at (1000w @ 1ohm) won't that be a bad thing when I am looking at 2 x 500w 4 + 4 DVC rms subs (wired in parallel/parallel for 1ohm load)?
I know, I know. I ask a lot of questions. But as I said I am not used to going over 500w rms. And usually bought Alpine, Pioneer or JVC equipment. Also I don't wanna spend all this money and blow something up within the first month or sooner.
asking questions keeps you from spending money on stupid shit. Were happy to answer them. your the type thats willing to learn not the type that comes in here knowing everything. Both subs are good i would go with the alpine even though i used to be sponsored by quart. Your subs will handle the amp fine.
