this is true for txi 4408 but instead i think im gonna go with a zxi 6408MobileAudio219 wrote:Yeah, you can bridge it, but then youre going to be running TWICE the recommended rms...
If you dont bridge the amp youre going to be running HALF the recommended power...
4 x 55-Watts RMS @ 4-Ohms
4 x 110-Watts RMS @ 2-Ohms
2 x 220-Watts RMS @ 4-Ohms
The amp just isnt a great match for your components...
finally bought me some components
- MobileAudio219
jgs07 wrote:this is true for txi 4408 but instead i think im gonna go with a zxi 6408
ZXi 6408 680-Watt A/B-Class
4 x 85-Watts RMS @ 4-Ohms
4 x 170-Watts RMS @ 2-Ohms
2 x 340-Watts RMS @ 4-Ohms
I really think you can find an amp that's better suited for you...
If you bridge the amp to your front components very bad things will happen.
brisgreat1
brisgreat1
2006 Audison LRx2.150 $275.00 ea Shipped, I have two of them
2006 Audison SRX1 2x60w 250 shipped I have one
Extra Clean signal, built in crossovers, they powered my Focal Setup all the way to the USACi World Finals.
Very good Condition ( the plastic xover covers are missing )
all my references are located here.
Also for sub duties I have an LRx1.400 that does 900w at 1ohm mono
Are you running them active or passive? If you are going passive, a 2 channel amp will do. If you are going to run them active, then you will need a 4 channel amp.
Also for power, if you are going passive, you will want a 2 x 100W @ 4 ohm amp. If going active, you will probably only need a 4 x 75W @ 4 ohm amp. Since the woofer and tweeter would be powered separately in the active setup, you would need less W/Ch.
EDIT: Only read the first page, so looks like you are running passive. Look for a 2 x 100 @ 4.
The LRx2.150s are 80x2
OnYrMrk wrote:2006 Audison LRx2.150 $275.00 ea Shipped, I have two of them
Man...I wish I needed some amps. those are great amps, and even greater prices.
Tim
Tim Strong
Email: [email protected]
X-box Live Gamertag:quad drpr
Tim Strong
