Help deciding on amp for subs
callandor2k
- Member
callandor2k
- Member
callandor2k
- Member
I listen to mainly hard rock, rock and occasional country. Little to no hip hop or rap. Would sealed or ported be best? I have always thought that sealed was better for the styles of music I listen to. Due to a quicker response time in a sealed enclosure. Don't get me wrong I'm not trying to steer away from ported. I'm just trying to figure all this stuff out so I can learn more about this stuff.
callandor2k
- Member
callandor2k
- Member
I'm gonna have to do some thinking on this.
I know if I go a single 15" ported. There will be no room for future expansion in my trunk due to box size compared to trunk size. Or could you use 2 15's in the same ported box as you would use 1 15 in. Or would 2 subs in a ported need double the space as 1? As I would like to have at least half of my trunk as usable space as I have a family so I will need to use the trunk a lot.
What about either running dual RWE-304 12's in a 1.085 cu. ft. dual sealed box ( 14 x 14 x 13.5 for each chamber external dimension ) or dual RWE-354 15's in a 1.643 cu. ft. dual sealed box ( 16 x 16 x 15 for each chamber external dimension ). Both wired at 1Ω load.
I know I won't be using their full potential in that configuration. But I am thinking of space.
Don't mind my ramblings. I am just trying to explore all possible routes I can go. And maybe learn a little in the process.
