PS Sound Cards with RCA Out
Robert Wollenberg
Post by Robert Wollenberg »
I have a hard time justifying the potential for problems both hardware and software or the expense, without it being able to do everything. I want it to be able to replace the HU and the processors before I make the switch. Once I can comfortably do that, I'll do it.
PCs can crush anything else out there as far as options. Look into software called "console". It uses plugins and routing to do pretty much anything you can think of. I think capable up to 384db/oct xovers, pretty much unlimited T/A, EQ, variable phase or anything else you can get a plugin for. There's another program called AudioLense which I believe does something similar.
from what ive been reading most guys who are doing it with a lot of success are using the pc as an aux source and still using a head unit to control most functions...id like to avoid that and use the pc for everything
Robert Wollenberg
smoker wrote:from what ive been reading most guys who are doing it with a lot of success are using the pc as an aux source and still using a head unit to control most functions...id like to avoid that and use the pc for everything
X2. I'll go PC when I can replace everything up front with it.
Robert R. Wollenberg
Audio Alchemy, Owner
Phone: (325) 480-2790
E-mail: [email protected]
Web: www.audiochemy.com
www.abilenecaraudio.com
www.abilenecaralarms.com
