CD service
brisgreat1
brisgreat1
k0rnyfr33k
NO NO NO.... do not even open it up dust can get on the lens.... use this http://www.newegg.com/Product/Product.a ... 6882160077
you might want to try to reinstall the drivers you dont need to reinstall windows.... check ide cable aka ribbon cable the one that connects to your mother board,hard drive and cd/dvd drive....and if none of these solutions work then its time to get a new drive
Its not the lenses in my CD/DVD drives. Its my CDs. After year of use and abuse it just needs to be done.
I tried a SkipDR about 5 years ago. it ruined a CD. I followed the directions... Heck I run machinery all day long, Im not going to be defeated by a hand powered device...lol
I havent sent them out yet Im waiting on the return of a CD.
colemanyoungerinalaska
transmission might be going out on the burner or the laser could be getting weak it can be fixed as there are little potentiometers inside you can turn up the voltage to it in slight incriments till it works then there the laser diode those can go bad sometimes the alignment of the laser can be off too and it wont be pointing where it should. allot of times though its a software problem or ide cable. as for getting scratches out brasso seems to do the trick
