Help with Aux out... im stumped...
loudwagon15s
if it has the i-bus aux in, my local shop had a cable for 25 bucks that i just installed in a friends deh3800 which obviously plugged into the bottom of the i-pod, not the headphone jack, into the i-bus, and a power and a ground coming off to wire it to a power source to charge the i-pod. Sounds great, and even though you can't control the i-pod from the hu (which i think is only playlists, and a few others), it saves you from the 70-80 $ price tag on the pioneer adapter.
yea i was trying to find one of those cables... and i def do have the i-BUS connector on mine because it is SAT ready... but i just got a FM transmitter of E-gay and if it works then fine if it sounds like shit then ill get that cable... I figured for $15 it cant be that bad... the only thing im worried about is if its battery operated... Hopefully it operates off of Cig lighter adaptor. If not im going to be a bit pissy cause i know that ill have to be changing in batteries every time i use it... Then again for $15 i could always open it up and wire my own cig lighter to the positive and negative leads... heheh
COR UNUM VIA UNA - Jay Chmura
