My First Amp Install
breakjunki
HELP!!! So I wired the power and the ground wires just fine, and the amp turns on, with no protect light, just a green power light. I only have my subwoofers wired to the amp to CH 5 and i have all three RCA's connected. The remote wire is run also. Why wont my subs work? I did turn some of the dials but the subs wont make any noise. http://www.sonicelectronix.com/item_6520_Hifonics+ZXi+8006.html# That is the amp and you can get pictures of it there too. Please Help!
- swimmerdude
Try taking a small piece of wire and use it as a jumper to go from the remote hook up on the amp to the power... This will tell you if it's a problem with the remote wire... Also check to make sure that you have the RCAs in the correct input and good connections at the h/u.
Well yeah, not having the sub hooked up would cause that
lol
Glad to hear ya got it fixed
