L7 or L5 and 2 or 4
Chances are if your brother had a Solo X installed with the L7s, you were probably hearing the Solo X, but feeling the L7s.
Since I recommended the L7 (would recommend Dual 4 ohm voice coils) for 2 of them, you're gonna require an amp that will put out around 1500watts RMS @ 1ohm. Some that I can personally recommend would be the Crunch GP1500D, Autotek MM1400.1D, Autotek SS1500.1D, Massive Audio P1500.1 just to name a few.
Nocturnal_Bird
Post by Nocturnal_Bird »
cargodz wrote:Chances are if your brother had a Solo X installed with the L7s, you were probably hearing the Solo X, but feeling the L7s.
Hello all, do you recommend Ebay, I like the kicker 1000 D or do you know any other good website to buy The amp I have VW Getta do you recommend 8 or 10 ? Thanks.
Nocturnal_Bird wrote:Hello all, do you recommend Ebay, I like the kicker 1000 D or do you know any other good website to buy The amp I have VW Getta do you recommend 8 or 10 ? Thanks.
Well as far as your ebay question. I personally would only recommend ebay for good quality used items unless you're not worried about a factory warranty... I always recommend that you buy from an authorized dealer to save from the headache down the road ;)
As for your 8 or 10 question, you're gonna have to be more specific... and you may want to think about starting a new thread for this question, so we can give it more attention :)
