Amp cooling/rack
I would use 1/2 wood, liquid nails and nails.
Build it as tight to the amplifiers as possible. Within a 1/2" from the top.
I have another question, the fans that i want to use (Stinger sf2) are 1 1/2" deep. So how would i go about mounting them on the cover of the amp rack if there is only 1/2" space above the amps. Do the fans have to be mounted flush with the amp rack cover's surface, or can they be mounted inch above it...
Thanks
Dave
Thanks
Dave
Sorry for the dealy been a busy guy lately (new G/F :) )
I would mount the fans on the end of the amp rack. The idea is to keep the airspace minimum so the fans can draw more air flow over the warm amps thus cooling them better.
Build it whatever it takes to make the amps/fans fit. If you have to put the amps on a raised platform inside the rack do so.
