Another follow up question. I finished installing the speakers and amp, and everything works/looks great, problem is, due to idiot (Circuit City) installation of my original sub (stupid), my sub RCA's no longer carry a signal. I'm pretty sure this is because they spliced my $50 RCA cable into some part of my stock wiring harness. My HU has a sub output, but it is only 1 RCA jack. I know this will be an easy answer, but do I just plug in 1 RCA, or do I use a Y connector?
Thanks again
George
4ch to 2ch?
Are you sure they didn't install a loc in the trunk off of the rear speakers?
And If you want to run multiple amps off of a H/U with only 1 set of RCAs, you have 2 options... The cheaper/ easier way is to run a Y connector, but the better sounding way is to run the RCAs through a crossover.
