Using a relay to isolate batteries?
nd4spd18
Post by nd4spd18 »
Well I talked to a guy at Motor City Reman today.
He called the company that makes the isolators that they sell, and they said that the regular isolators can be used with a Deco CS alternator, but I would have to run a wire from the car's ignition wire to the alternator + terminal, with a 10 amp diode in-line.
I'm guessing that the isolators designed for the CS alts do that internally, and that's why they have a terminal for the ignition wire.
Ever heard of that being done?
yeah GM uses a setup that monitors alternator function.. that's all. the ECM has to be able to see the voltage output so it knows the alternator is working properly.
Don't ya just love OBD-II garbage?
nd4spd18
Post by nd4spd18 »
Actually it has OBD-I... its a 94. The guy said that the diode should be installed so that current can flow from the ignition wire to the alternator, because the voltage regulator has to see voltage to activate it.
Does that sound right?
nd4spd18 wrote:Actually it has OBD-I... its a 94. The guy said that the diode should be installed so that current can flow from the ignition wire to the alternator, because the voltage regulator has to see voltage to activate it.
Diodes are used to make sure electricity only goes one way.
diodes limit current to one direction just like he said.
Beachcrawler
Post by Beachcrawler »
This is my setup. I hope this helps.
http://www.dodgetalk.com/forums/showthread.php?t=128210
qlc1964
dual battery
Post by qlc1964 »
hey!!!! i just installed that stinger 200 few days ago my set up is dual alts i`m adding a 2nd batt on the stereo charging system for longer playing when watching movies. i use the autozone yellow top batt if i had the money i would buy two at the same time. the stereo batt i had for 3 months and i haven`t bought this other batt yet. i use a rocker switch to turn on the system and i wired a relay to the remote wire to trigger the stinger 200. so when the systems off the two batts want drain each other from days of sitting. this batt will be mounted underneath in rear next to the leaf spring passenger side. :scorp:
I'd recommend you go with a deep cycle gel cell battery for the audio system, and put it on an isolator.
that way fully discharging the battery won't damage it the way you would with a normal lead acid starter battery
Beachcrawler
My Stinger 200 is triggered by my cigarette lighter (switched) circuit. Plus I have the Relay-delay that only combines the batteries when my alternator is charging at > 13.3 volts. My second battery is a deep cycle as suggested by GlassWolf. I also added a momentary switch so the deep cycle battery could jump the starter battery in an emergency without using jumper cables. If you connect the Stinger as shown in my link above you won't need extra switches and your system will operate automatically.
qlc1964
Post by qlc1964 »
but . don`t it take longer to fully charge a deep cycle batt in the car if you was to drain it pretty low? when your system starts cutting off &on you know it`s time to start the car :surprised
