Yet another capacitor thread
energumeno wrote:1. Is it possible to place the capacitor before a fused distribution block? (Some manufacturers say yes, some others say never put a fuse between the capacitor and the amp.)
can you? yes. Is it as effective? questionable.
you want the capacitor to be as electrically close to the amplifier as possible, so between the fuse block and the amp is ideal. It's also generally advised to use 1 farad of capacitance for every kilowatt of power the amp is rated for, so sharing a cap between amps isn't the best idea. Better to dedicate caps to each amp ideally.
2. Should I wire the ground of the capacitor to the same grounding point of the amps or should i ground it to a different point in my car's chassis? (Again some manufacturers say to ground at a different point, some others suggest at the same point to avoid grounding loops.)
What do you think?
doesn't matter. common ground anyway as long as you use sufficient gauge wire to handle the current draw, and have a solid ground connection. Your car's chassis is equal to 4AWG wire anyway due to spot welds that hold the unibody together, so if you need more than 4AWG wire for the system, you're better off running 0AWG wire directly to the battery negative terminal anyhow, and using a grounding distribution block.
http://www.bcae1.com/capacitr.htm
http://www.glasswolf.net/caraudio/capacitors.html
http://www.glasswolf.net/caraudio/charging.html
http://www.betteraudio.com/geolemon/newmain/battcapalt/
http://www.bcae1.com/charging.htm
http://www.bcae1.com/chargin2.htm
http://www.bcae1.com/battiso.htm
http://www.glasswolf.net/caraudio/batteries.html
http://www.the12volt.com/info/recwirsz.asp
http://www.optimabatteries.com/
these sites are invaluable information on charging systems. Please take a moment to at least skim over them.
Geolemon, Perry Babin, and I wrote most of these articles and all three of us have backgrounds in electrical engineering and the mobile audio industry.
geolemon
Post by geolemon »
I bet you couldn't find any manufacturer who actually would say "ground to a different spot"... in other words "don't ground to the same spot as your amps".
The closest you might find would be a manufacturer who states that you don't NEED to ground the capacitor to the same spot as your amps, but that doesn't make it a bad idea - and no manufacturer would [have any basis to] claim that it is a bad idea. ;)
Not to nitpick - but anytime that anyone says "some manufacturers say... while other manufacturers say..." and in reality, they don't really know any information from any manufacturers - that's misleading, and it's the wrong way to start a thread. ;)
