jonnyb wrote:we do remote starts too. its 75% of the business in the winter.
ours go like this:
basic remote start, no bypass required: $99
if it needs a bypass, we upgrade the model, and its $200, with bypass.
we also have 2way remote start systems @ $225.
i acctually enjoy installing them too.
has anyone done 06 or up chrysler dodge, or jeep? ha, thats a ball of fun.
just for fun i pulled up an 06 dakota,,,lots or fun there...
12volts red, red, red/lt. blu (40A ea) + ignition harness
Starter pink/lt. blue + ignition harness
Second Starter N/A
Ignition pink/lt. green + ignition harness
Second Ignition pink + ignition harness
Third Ignition N/A
Accessory purple (-) and pink/white (+) -,+ ignition harness
Second Accessory pink/yellow (x2) + ignition harness
Keysense purple/tan - ignition harness
Power Lock purple/dk. green - DKP or cluster, gry 16P plug, pin 3
Notes: Lock is negative trigger thru a 330 ohm resistor. Unlock is negative trigger thru a 100 ohm resistor. MUST use relays.
Power Unlock same as power lock wire
Lock Motor lt. green 5wi DKP or cluster, gry 26P plug, pin 15
Unlock Motor tan/lt. green 5wi DKP or cluster, gry 26P plug, pin 12
Parking Lights+ pink/red (L), white/orange (R) + IPM, 20 pin plug, pins 15 and 17
Notes: The IPM (Integrated Power Module) is the fuse/relay box on the driver side fender.
The rear taillight wires run from this location down into a harness that follows the frame rail to the rear of the vehicle.
Parking Lights- pink/red - sw. or cluster, gry 16P plug, pin 5
Notes: Parking lights are negative trigger thru a 1130 ohm resistor. MUST use a relay.
Hazards white/orange - sw. or cluster, gry 16P plug, pin 8
Notes: The hazard lights are negative trigger thru a 120 ohm resistor. MUST use a relay.
Turn Signal(L) wht/lt. grn(F), wht/dk. grn(R) + FCM, 12 pin plg and IPM, 40 pin plg
Notes: The FCM (Front Control Module) is attached to the IPM (Integrated Power Module), which is the fuse/relay box on the driver side fender.
Turn Signal(R) white/tan (F), white/orange(R) + FCM, 12 pin plg and IPM, 40 pin plg
Reverse Light white/lt. green + IPM, 40 pin plug, pin 27
Door Trigger see notes - each kick or cluster
Notes: The LF door is purple in the gray 26 pin plug, pin 6. The RF door is purple/white in the white plug, pin 23. The LR door is purple/gray in the gray 26 pin plug, pin 8. The RR door is purple/yellow in the white plug, pin 22. Use all four wires and diode isolate each.
Dome Supervision yellow/orange + cluster, white plug, pin 11
Notes: Also found in the passenger A pillar.
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm factory remote only
Disarm No Unlock with ignition and Sentry Key
Tachometer NOT red ac any ignition coil or fuel injector
Wait to start N/A
Brake Wire white/lt. blue + brake pedal switch
Parking Brake dk. green/white - sw. or cluster, gry 26P plug, pin 3
Horn Trigger dk. green/purple - sw. or cluster, gry 26P plug, pin 10
