mb quart question
carco_dr
Post by carco_dr »
so how do i use the FAQ? i clicked on it and it has a couple of spaces to search. what do i do? thanks for your help.
carco_dr
Post by carco_dr »
i went into the FAQ as suggested but what do i do once i get in? it has a couople of spaces to search. i am unsure how to look up subs. thanks for you help.
two4fifteen
Post by two4fifteen »
no. click on the forum button first(not faq), then click on the "faq, guides, and information".
carco_dr
Post by carco_dr »
alright, i got it, thanks for the help.
carco_dr
Post by carco_dr »
so i picked out a few brands of subs. what is suggested. i have a 2002 silverado ext. cab and obviously little space under the rear seat. i do not know the dimensions for a box to hold two 10s. anyone have an idea or anyone made a box for a truck like mine. I need subs that will fit and have sufficient air space, so based on what i have read these are the subs i picked from the FAQ good, bad, ugly list: Accendant Audio, Boston Acoustic, Alpine (Type-X), Diamond Audio, JL Audio, Kicker (Comp VR), and JL Audio. I just picked these because I have read other people have them but are they good enough for my truck? I am on a budget but I am more concerned with which sub will fit underneath and sound good as per my previous post.
look at the alpine type R, instead of the type X.
all around better sub for your application.
brent
Post by brent »
As far as enclosure is concerned the enclosure for your truck is mass produced in the prefab industry. I am not recomending prefab by no means however, but if you go that way be sure to reinforce the inside of the box. I second Glass on the Alpine Type R. Also, the CVR and Ascendant are very good subs as well.
carco_dr
Post by carco_dr »
what to i reinforce the box with if i go prefab? and what Ascendants will work for my truck? I have a Rockford Fosgate 501 bd amp (300 x 1 @4 ohm, 600 x 1 @2 ohm.) Is it difficult to build a custom box for two 10s? How can I get one with an amp rack to put my amps (one for subs, other for components)?
Thanks everyone, sorry for all the questions.
brent
Post by brent »
If you have a tablesaw no it is not dificult to build a box. With prefab boxes I always reinforce with chunks of 2x4's other may have a better method. I would probably just go witht he assassins unless you are wanting more. THey are single 4 ohm coils so a pair would split that 600watts. As far as finding a box with a rack on it, I would say just look around, see what you can find. There are people on this forum who build boxes if you wanna go that route. Just ask and they shall make known.
carco_dr
Post by carco_dr »
where on the box do you reinforce? and about the assasains, how do they sound? i like my music loud and clear and also to be able to hear that bump inside and outside the truck. have you heard of diamond audio subs and are they good for my application. what others would you suggest with the amount of power i have.
