led's
Darthness
Post by Darthness »
maybe yoiu can help me... i want to do a LED dome light for my car. im probably going to go out and buy the LEDs and stuff today.e do i need to buy one of those boards like you used with the tail lights?
- Keith
joeyc
Post by joeyc »
is it necessary to have a resistor when using 2 aaa to supply like 5 or so? forward voltage is 2.4. it says to use a 33 ohm, but is it really necessary?
JC's Customs
Darthness
Post by Darthness »
I ordered 20 super bright green LEDs w/resisotr and i bought a DMM today. i want to use some of these in a domelight for my car...
- Keith
joeyc wrote:is it necessary to have a resistor when using 2 aaa to supply like 5 or so? forward voltage is 2.4. it says to use a 33 ohm, but is it really necessary?
the resistor controls current.
Darthness wrote:maybe yoiu can help me... i want to do a LED dome light for my car. im probably going to go out and buy the LEDs and stuff today.e do i need to buy one of those boards like you used with the tail lights?
Ya, that will be the easiest way to do it. Just cut it to the size you need, and then solder in all your resistors. Just make sure you get the polarity of the LEDs right, other wise it won't light up :)
Yes as Kiki said it controls the current, otherwise you could blow out your LEDs really quick.
I get all mine from Oznium.com. Great service and great product.
there a lil expensive per led i think a 1.39 or 1.5 per is a lil high... when you can make them for like 10 c
joeyc
Post by joeyc »
Justin from Detroit wrote:I get all mine from Oznium.com. Great service and great product.
yeah, just bought some from there, BUT they don't have as wide of variety as some others. But they are definitely competitively priced!! do the uv's work pretty good? OH and how well does filing or cutting the top of the led effect the dispersion of light?
JC's Customs
joeyc wrote:yeah, just bought some from there, BUT they don't have as wide of variety as some others. But they are definitely competitively priced!! do the uv's work pretty good? OH and how well does filing or cutting the top of the led effect the dispersion of light?
I've never done either before, but I would think it would affect the viewing angle some.
