Help with amp decision...
The sub that you listed in the link says they are single 8ohm. Do you know what yours' is?
If they are 4ohm subs this is how you wire them
http://www.rockfordfosgate.com/rftech/w ... l+-+4+ohms
So look look at your subs and there should be a sticker or somthing that says 4 or 8 ohm.
They are 200rms per sub, not 400.
JL Man
Post by JL Man »
Hifonics NX400, 400 watts at 4 ohm mono. should be perfect
hype
Post by hype »
kevinberry1 wrote:Check with RF's website in their archives. I found this really quickly
http://www.rockfordfosgate.com/scripts/ ... ZT0x&p_li=
If these are the subs then it appears they are single voice coil in either 4 or 8ohms, for your sake I hope they are 4.
thanks.. i actually went there but i couldnt find my speaker.. i didnt know they had an arcieve...
i was able to check the subs myself today and they're definately 8 ohm with 200 watts RMS and 400 Watts Peak....
hype
Post by hype »
High Society wrote:The sub that you listed in the link says they are single 8ohm. Do you know what yours' is?
i was finally able to check them out today and they are 8ohms but the place i got everything hooked up at had them hooked up like the wiring option 1 is that right?
thanks again for everyones help.. im starting to understand a little more lol...
hype
Post by hype »
JL Man wrote:Hifonics NX400, 400 watts at 4 ohm mono. should be perfect
now that i found out for sure they're 8 ohm is this amp still going to work? or can i only use an amp at 8 ohm?
JL Man
Post by JL Man »
2 8 ohm subs make a 4 ohm load. yeah the amp will still work.
hype
Post by hype »
JL Man wrote:2 8 ohm subs make a 4 ohm load. yeah the amp will still work.
oh alright i understand now.. thanks for everyones help....
JL Man
Post by JL Man »
no problem
