Dynamat and JL Audio CL-441 clean sweep
Post by audiobass10 »
Darthness wrote:i've heard peel n' seal and other asphalt based deadeners can put off dangerous fumes and have lower heat resistance.
http://www.secondskinaudio.com is alot cheaper and i belive slightly better than dynamat.
I never smelled anything. I think whoever said that was a little... :scorp: . It's not like there's a lot to a sound deadner. Why spend a fortune.
MobileAudio219
Post by MobileAudio219 »
audiobass10 wrote:I never smelled anything. I think whoever said that was a little... :scorp: . It's not like there's a lot to a sound deadner. Why spend a fortune.
Sure there is, heat ratings, glue strengths and more... That's like saying that there isnt a difference in tires, they're all rubber and they all roll, right? ;) ...
[quote="MobileAudio219"]Sure there is, heat ratings, glue strengths and more... That's like saying that there isnt a difference in tires, they're all rubber and they all roll, right? ]
Well if you can tell the difference between dynamat and peel n' seel...then your ears are much better than mine ;)
you want a butyl based mat, as opposed to asphault based.
The asphault stuff just stinks up the car for a few weeks.
The quality of the adhesive makes a big diffeence as well if you're using it in exposed areas like trunk lids.
Look at other brands than Dynamat, like SecondSkin, eDead, Brownbread, Hushmat, RAAMat, etc.
Cheaper, but still thicker and better than peel and seal.
MobileAudio219
GlassWolf wrote:you want a butyl based mat, as opposed to asphault based.
listen to the man...
To each their own. :fing02:
I'm not arguing about it. I'm just offering the pros and cons to consider.
ice shield works.. it's just not as thick,doesn't always adhere as well, and tends to stink a little.. but it is a lot cheaper :) the smell goes away eventually.. if it doesn't come unstuck, you're fine, or you just glue it back on, and you can layer it.
The thicker or more dense the material is, the more mass it adds to the metal so the better it'll generally work.
fwiw
