Knocking noise
CerwinVegaMan-VS100
Post by CerwinVegaMan-VS100 »
William from NOLA wrote:If you can take the speaker out and place your hand behind the cone, push outward gently (and evenly), if you see it detaching, then you will know for sure.
See the cone detaching from the spider?
Yea, it would be obvious.
CerwinVegaMan-VS100
Thanks for all your help, i will try that in cpl minutes.
It is no trouble.
Also, the cone may not be fully detached, so be sure to check all the way around it for any separation.
Also check the surround real good, If it's separated from the basket that can cause problems too
