speaker help
ksimms
Post by ksimms »
Iplan on adding a sub once I get my rear speakers problem solved
Uhhhhhh, fix the problem and then move on. If you leave it, and just do something else, you will only cause more problems for yourself.
I would get a soldering gun, and some shrink tube, or some simple crimp conecors an redo your wires. Then add a sub and amp. If you don't it will end up costing you alot more money in the long run.
Blitzzzkrieg
Post by Blitzzzkrieg »
or just use wirenuts man...pull it out, wirenut ur wires and ur good to go
Post by audiobass10 »
Take the unit out..Check the rear speaker connectoin..even if it looks good redo it..should work.
JeremyC wrote:Uhhhhhh, fix the problem and then move on. If you leave it, and just do something else, you will only cause more problems for yourself.
And if you don't have shrink tube, electrical tape does you good.
William from NOLA wrote:And if you don't have shrink tube, electrical tape does you good.
If you solder the wires first. As you have experianced just twisting the wires and taping them doesn't hold to well. (just wanting to clarify william, I knew what you meant)
The reason I like shrink tube, is it will never get hot and come apart. Electrical tape can, especially in hot wet
climate.
Blitzzzkrieg wrote:or just use wirenuts man...pull it out, wirenut ur wires and ur good to go
I don't like wire nuts. Yeah crimp conectors are ok, but wire nuts don't do well under vibrations, and most people use the wrong size which leads to even more problems.
Blitzzzkrieg
i uuse the small grey ones, always have...ive never had a problem with them coming lose...just screw em on till the wires start to twist and u'll be good...i HATE those crimp connectors....ehenever u wanna take the unit out, u gotta cut and restrip ALL the wires
Chris from MI
Post by Chris from MI »
If you dont get anything by checking the connections you may want to check the run of wire to make sure there isn't any splits or the wire is damaged or worn through somewhere.
