so it full perform full output with 2 subs? i thought it usually doesnt perform full output? rms is what is performsWilliam from NOLA wrote:For that amp, yea those would be better to buy. That way you will be able to get 300 to each sub, which will allow them to play close to their best.
will this amp bring out full power for these subs?
snakey51389
veggie-man
Amp:http://www.onlinecarstereo.com/CarAudio ... ctID=15324
Sub: http://www.hifisoundconnection.com/Shop ... 7236247234
you could get this amp and get the duel 2 ohm voice coil. make sure you wire the sub to 4 ohm's and bridge the amp... this is the exact system i have
if you do get this amp do not get the Dual 4 Ohm Voice Coil Subwoofer because you would only be able to wire it to 200 RMS 2 ohms
I don't understand what you wrote, but the idea is that you want to want to be able to give subs close to their recommended RMS rating without going over. The difference between 300w and 400w to the subs will be only a small change in output. It's more a matter of efficiency with the sub.so it full perform full output with 2 subs.
veggie-man
ok i didn’]http://www.hifisoundconnection.com/Shop ... 1244239238)would[/url] work if you got 2 of the 4 ohms duel voice subs (http://www.sonicelectronix.com/item_5527.html) they would be getting 300 rms at 2 ohms.. they would be a little under powered by 100 rms but it wont hurt any.snakey51389 wrote:^yes i am going to buy 2 subs.
snakey51389
veggie-man
William from NOLA wrote:nobody ever knows, you aren't alone...
http://www.caraudiocentral.net/forums/f ... ay.php?f=8
purt near.........it means "almost" dang william, you being from looziana and all i figured if anyone understood that it would be you.....
Heck far...I purtnear got the giggles aftah readin yur post thar Terry. That bout made me jump up and skweel like a pig. Soooooeeeeee!!
somewhere in the distance, dualing banjo's plays in the mist....
I was gonna have a hissie fit when I seen you pickin' on the south, I got a good notion to cut a switch and whale the dickens out of you. Some people are a right far piece from havin a lick of sense, don't let your mouth overload your tail.
Willie ain't nothing but a coon-ass, though
Lots of em down yonder in Louisiana
