need advice on sub and amp for Trailblazer
first off let me know how you like this truck i was thinking of buying one. second i agree with onyrmrk above on a new car like that i would spend the extra money for the clean sweep. you may say yea its 300 dollars and i can just use the 17 dollar piece. there alot diffrent and you sound would be much better with the clean sweep. my sub reccomendations the elevation pro would be a good choice diamond d6/d9 is a great woofer. there are many out there focal mb quart just dont go off and get something take you time and research the brands and the companys.
Give us some more info on the MTX amp.
Maybe just the JL Clean Sweep and a new sub/box...
Keep the cost down :)
Amps have gotten a bit better in years. But most stride has been made in subwoofers...
OnYrMrk
Post by OnYrMrk »
Also Tim I was just thinking about the Stealthbox that JL has. You don't even know it is there. Doesn't take up much if any room and you have a 10" sub for good bass. Will take up to 400 watts and that will help keep the cost down. Only problem is that it is pricey. I will try to scavenge up a pic and post it for you.
OnYrMrk
Post by OnYrMrk »
thanks Ryan
tim87tr
Post by tim87tr »
Bwcad1 wrote:first off let me know how you like this truck i was thinking of buying one. second i agree with onyrmrk above on a new car like that i would spend the extra money for the clean sweep. you may say yea its 300 dollars and i can just use the 17 dollar piece. there alot diffrent and you sound would be much better with the clean sweep. my sub reccomendations the elevation pro would be a good choice diamond d6/d9 is a great woofer. there are many out there focal mb quart just dont go off and get something take you time and research the brands and the companys.
I'm on this Buick board where they got me interested in the Trailblazer SS
http://www.turbobuick.com/forums/showth ... p?t=172709
Thanks everyone for the info and links. I'm going to strongly consider the stealthbox and cleansweep as I like the look, what I read and the OEM aplications.
Appears that I could just mount an amp vertically on the stealthbox. Any other suggestions on an amp that will work with the JL stealthbox/300w rating. I will shop around for prices unless someone has a suggestion. I've bought off Crutchfield before but that's the limit of my online audio purchasing knowledge.
Yea, if you want to keep max cargo space then the stealthbox is the way to go. It comes with an awesome sub too. It should keep you happy. As for an amp, you could always keep your system full JL Audio and go with a 300/2:http://www.sonicelectronix.com/item_1171.html
or a Rockford Fosgate P3002:http://www.sonicelectronix.com/item_2522.html
Just 2 suggestions. There are a ton of amps out there that will push that sub nicely. If you want to keep the price down on an amp, look for a 2 channel that is bridgeable to 300x1 at 4 ohms.
OnYrMrk
Post by OnYrMrk »
I was thinking more along the lines of an e2150 bridged mono. For 160.00 you can't beat the quality of that amp. but yea, the 300/2 would work too.
