Box Terminals
raw9283
Post by raw9283 »
I was planning on sealing the speaker wire hole with silicone...any benefit to using liquid nails in that application?
raw9283
Post by raw9283 »
This time of year, you can't beat the weather here...I lived in Ohio until 4 years ago and I can't take the cold anymore when I go back for Christmas
raw9283
Post by raw9283 »
I also read somewhere that it's good to drill pilot holes before drilling in wood screws. Anyone agree?
Yep it is. It keeps the wood from cracking. Just make sure you use a bit the same size as the shaft of your screw, minus the threads.
yea definitley predrill your holes....as far as sealing up the hole where you put the speaker wire through i prefer either urethane or a thick caulk like the stuff for roofing. i have had liquid nails chip away around speaker wires so i prefer to use something a little more flexible for that
i use a good quality terminal and havent had a problem yet. binding posts work great and i can get you a link to that if you want.
raw9283
Post by raw9283 »
Anyone know an easy/cheap place to get split loom?
jonnyb
Post by jonnyb »
i freaking hate terminal cups. they are the makings of the devil.
I get split loom real chap through my wholesaler
raw9283 wrote:Anyone know an easy/cheap place to get split loom?
http://www.selectproducts.com has loom in 100ft. lenghts for pretty cheap.
