Wattage sucks
Minorthreat412 wrote:I still have one more question. Sorry. What if you have a 2 channel amp hooked up to two 4 ohm SVC subwoofers. What will the resistance be/How much power will the amp be putting out to each speaker?
Now, what if you hooked up two dual 2 ohm VC subwoofers up to that same amp. What will be the power and resistance rating?
Sorry again for these questions. It's taking me so long to understand. I don't know how 2 channel amps work exactly. Mono amps are easy because they are just ran parallel off of 1 channel. I don't know. Thank you again.
If you were to hook up 2 SVC 4 ohm subs to a 2 channel amp, your best bet would be to run each sub to a channel. This way, the amp can play at 4 ohms per channel w/o the risk of killing the amp.
If you were to hook up 2 dual 2 ohm subs to that same amp, then i would bridge the amp and run the subs in series to produce a 4 ohm load on the amplifier.
Most monoblocks are rated down to 2 ohms or 1 ohm. Monoblocks are basically designed to be used for subs only, since they dont play in stereo.
Do you have a setup now that you are trying to wire up correctly? Or are you just trying to learn before you buy something?
im pretty sure hes just trying to learn vc configs ands ohm loads for amps...
